A few details. The 10th Anniversary E-Ignition will be available next week for $198.95.
The installation is the same as the original basic PAMCO, but new instructions will be posted. It will also be available with the 12mm aluminum advance rod for the '80 to '83 models. The E-Ignition includes the mechanical advancer substitute cap to completely eliminate the mechanical advancer. If you currently have a basic PAMCO with the 60 degree rotor, you can order the new E-Ignition for $169.95 and reuse your 60 degree rotor.
Finishing up this cafe. I have a Boyer installed and I’m not liking it. Brutally honest, it’s a p.o.s. The release of this new Pamco, well its perfect timing. (No pun intended) haha!
This is going to be perfect for my bobber, what with the single cable coming out and all. I can use my e-advance on my stock budget build, where wires are far easier to hide.
Pete
I'm looking forward to using this on my next build. My current bike has the previous Pamco and E-Advance and is the best thing I did on the build.
FYI. There is a small tyop on the link that takes you to the Installation Instructions.
I will add that the stock locating pin on the cam needs to be modified in order for this to work. My stock pin and the several I have from Mike's don't fit in the groove on the advance replacement rotor. They need to be cut down as they are too long.
