XS750 gears in the XS650 for strength
Ratranger
XS650 Junkie
Oklahoma
Won't stay in 1st? Undercut the drive dogs. Made an adapter to hold the harbor freight flexable shaft grinder in a tool post, mounted the milling attachment and dialed it in for a 1.5* undercut. I'm debating an overdrive 5th to go with the undercut 1st and xs750 3rd.
Nice way of doing the undercut. Was the XS 750 third gear swap straight forward?
Also considering doing the swap for a new motor, but I have not heard of any problems with the XS 650 third gear.
The swap is pretty much drop in. The biggest hassle is the snap rings being a pain. Just make sure you get a 750 tranmission not an 850. Best I can tell is pre79 750 transmission has the right gears, later transmissions have one gear that has smaller dogs than the 650 on one side.
Is the third gear swap just to replace worn parts, or is it a different ratio?
Can you detail the undercut procedure? Maybe do a thread on it?
thanx!
Nice, since I have a later 850 trans here is a close up of the gears I highlighted as "wrong" above. You can see how much yamaha removed from the dogs on the one side and the matching smaller dogs on the mating gear. The older large dog gear won't even fit. So best bet is to check the ebay pics close, you can see the difference if the pics are good.
Yep, that's me. Did a little riding yesterday to start tuning. Honestly you don't notice any difference with the xs750 gears in there. They may be an upgrade in strength, but they are unnoticeable in use.
This is very interesting work and quite impressive - but I must ask, is there an extensive history of gear failure in unmodified XS650 trannies?
I can see it if you have increased power markedly, but as far as I am aware, stock XS650s seem to never die (but I may be wrong on that score).
Pete
How is your drum, detent. I realize it's not the exactly the same but had an old BSA which would jump out of 1st. Turned out to be a worn cam plate that moves and holds the shift forks in place. In these trannies it's a cam drum and a some sort of ball or plunger spring detent to hold in position. Also check the spring.
Same principle though, You could be looking in the wrong place. Just a thought.
The spring and detent are fine, as is the drum itself. The shift fork was worn down, but that is more of a symptom than the problem. When I set things up to do the undercut the dogs weren't straight, they had almost a degree of chamfer that under load would push things apart. The undercut so far has solved the problem.
It may be mainly a racing mod, and honestly I just did it because if I was going to pull the motor, it was going to have the best transmission it could. Did I really need it? Probably not. I think for most people it would be a peace of mind mod, not really needed but you know it's as strong as possible.
My first XS650 broke it's second gear. One of the dogs broke off. No transmission lock up when it occurred. It just went into the oil sump and stayed there until the next oilchange. I could hear the tranny "chirp" when it was in second but, other than that, it was fine. I did do a shaft swap out one evening to fix it.
I went thru a few XS650s in my youth, when I rode with a bit of "enthusiasm". Neve broke a 650 trans or saw one with a problem, aside from the sticky clutch BS.
