Left hand switch wiring.
Prisondawg
Illinois
I went ahead and bought an aftermarket switch.
But in having a hard time finding a simplified diagram. To wire it up.
My stock harness should be
Yellow
Yellow/blue
Dark green
Dark green
Blue green
Yellow blue.
Here's a picture of the aftermarket switch
I know someone knows these wires a lot better than I do.
The wire colors you list are pretty close to what is used by the headlight dimmer switch, except your last entry. The yellow blue should be a yellow/black. In the diagrams Yamaha used an L for blue and a B for black. So a Y/L is yellow/blue. Y/B is yellow /black.
How many wires come out of your new switch? and did it come with a diagram showing what wires do what.
If no diagram you will need to do some checking with a meter to determine where each wire hooks on to which switches.
The wiring changed through the years, so telling us what bike you have will help us help you.
A lot of us put our bikes years, models and mods in our signature line.
Oh im sorry! I meant yellow black. I have the 78 special. I use the "2FO" serial code in the clymer manual. Also I included a picture of the diagram that came with the switch. Thanks for your reply.
Here are some pics inside the stock (black) and the aftermarket (chrome)
It sort of all looks the same with the exception of the lime green. (That might be for a self canceling unit)
My bike doesn't have a horn or a eStart so I wanted to use those buttons for momentary turn signals. Left horn and right started button
On your stock system there was a few things that may not function with your new switch. Self canceler, is one. The RLU is another.
your diagram has some numbers, these are in a plug correct? There are others listed just by color, I assume these are out by themselves.
New switch plug your harness.
#1 yellow-----------------------------------Dark green both go to the headlight low beam
#2 blue green-----------------------------
#3 blue/yellow----------------------------
#4 pink-------------------------------------Pink wire from horn
#5 Brown/white--------------------------Brown /white from flasher
#6 Yellow/red----------------------------
D/Gr----------------------------------------D/Gr right turn signal
Brown--------------------------------------Chocolate or dark brown Left turns signal
Black---------------------------------------Hook to ground on frame or into the black harness ground
Yellow-------------------------------------Yellow headlight high beam.
L/gr-----------------------------------------
On your stock system the other wires from your harness hooked the left side switches to the Reserve Lighting Unit and the turn signal self canceler. The #6 y/r may hook to the R/Y on your harness. This goes to the self canceler.
On the headlight dimmer switch of the new switch the blue/green or the blue/yellow is power in. One of these wires should hook to the yellow/blue from the RLU.
That's about all I've got.
Do you still have the stock left side switches? If so you can use you meter to check both the old and new to compare what the switches send power to which wires. This may help get everything working.
I don't know just what you are doing. Trying to keep it stock or to simplify things.
As far as simple goes this diagram work well. It shows a basic points ignition with the separate regulator and rectifier. In boxes it has the later TCI and combo reg/rec. E-start is in the upper right corner.
It doesn't show the turns, but are not hard to add in. You can hook to the Brake light fuse, run a brown wire to a flasher, From the flasher with a brown/white to the new switches brown/white wire. From the new switches out to each side, right is dark green, left is dark brown.
I'm not sure how you can use the horn and start buttons for turns. These buttons just hook to ground. Some sort of relay might work.
Unless you use a turn system off of a Harley, they work that way. A left and right button. Don't know just how they work.
Thanks for the write up, I'll try it all out when I get a day off! And let you know how it goes. Hopefully no fires.
