That looks oddly familiar...
I've used Torque ever since it started. I don't think you'll find an app that's as easy to use.... or as complex as you want to make.Bike has a OBD2 port in a "euro" configuration, will need to get a dongle and software, groan.
Well the bad news; it has a bad head gasket. new plug wet with oil after a 2 minute run 80PSI compression, other side 180PSI.
The good news is the head is sticking out where god and even a lowly wrench twister like me has easy access. Since it's air cooled, cam in block it should be no more than a 3 hour job even the first time . The Moto Guzzi Distributor is only 80 miles away, parts are cheap AND in stock, $38.00 2 valve cover and 1 head gasket with tax and shipping..
Common issue for this bike.
have that, blue tooth dongles and Ford and Toyota specific software. Euro bike ports are more differenter. 'nother 'dapter needed.I've used Torque ever since it started. I don't think you'll find an app that's as easy to use.... or as complex as you want to make.
When I was teaching, my students borrowed it all the time.... prolly hundreds of tests and sensors replaced. I don't recall it ever being wrong on fault analysis. It's been well worth the 30 bucks I invested.And to think you can just slip all of that into your pocket, simply amazing!
KInda, racked up some miles on a K1200 All the bimmers suffer from feet must be behind motor disease.Sorry to hear your problems are worse than hoped. Happy to hear that ( for a man with your abilities ) the fix is a relatively easy one. It is nice to have parts out where you can easily access them. The valves are simple screw adjustments also.
BMW’s are even easier to work on, everything is just hanging out in the wind. By the way, o know you are on the hunt for a new ( old ) touring bike, have you ever owned a BMW? That just what they were made for! And boy are they durable!
Just what I was looking for, someone who has actually used this app. Would you recommend the basic version?I've used Torque ever since it started. I don't think you'll find an app that's as easy to use.... or as complex as you want to make.
Don't know about the basic version. Torque Pro is all I've used... at 5 bucks it's a steal.Just what I was looking for, someone who has actually used this app. Would you recommend the basic version?
I want to use it on my car along with a vgate diagnostic plugin. Thanks.
I'm also using the Vgate adapter. Highly recommend both.
