Wiring fixed, everything new, added a fuse, works good. Doesn't appear to be charging but that's a problem for another day. Likely the generator needs some love.
Hydraulics work but beaucoup leaks and fluid looks like chocolate milk where it's leaking out of the cylinders. Water in the oil for sure. No problem, drain it all out anyway. Cylinders will need to be kitted, all the hose connections will need to be cleaned, sealed and tightened.
Scared me for a bit, the control setup is different than I've seen before. Two valves sticking out of the body. I at first assumed that the top one was "UP" and the bottom one was "DOWN". Nope. Nothing happening. Rut-ro...
I had taken the lever off as part of the disassembly to get to the trans and I remembered it had two rods operated by one handle. Hmmmmmmm...I wonder... Yup, BINGO. "UP" is pull out the top valve and push in the bottom, "DOWN" is pull out the bottom valve and push in the top.
Whew...
