There's several stuck piston pusher ideas round here. I've gotten out some severely rusted ones. it is very important to send them both down at the same time or you can damage crank, connecting rods.
yeah, tried all kinds already, I'll keep on going, drilling the pistons is my lat option!Never personally heard of anybody trying the method you suggest. I'm not saying it wouldn't work. Might make a lot of mess, but you would have to be ready for swarf everywhere. And it might be that the pistons are better stuck than most and reluctant to shift.
What usually works is releasing oil, leave it a while, then tap the head of each piston with a wooden drift, typically start with a hammer handle, working around the edge of each one and increasing the level of force until it moves. Have you looked at 5t's patent piston pusher? I guess you have 'coz you've seen his ingenious engine stands.
Good luck!
Wasn't HE clever!off for night-shift today,
working on seized motor, no chance to move the pistons, found out the reason the starter where in a box, homemade plug, hard plastic with a bolt thru the case cover, not too bad, the starting gear still in the lower case,
So every engine, every bike I ever owned have there own story,
You guys may have the same background with every bike you owned,
Would be a idea for a thread?
Didn't find it........ the picture with the extended clutch spring? ......
Hey, 5Twins,For reasonably priced oversized pistons, check out cruzinimage. They also sell on eBay .....
https://www.cruzinimage.net/2017/08/17/yamaha-xs650-0-5mm-oversize-pistons-set-447-type/
HiNote: the normal "needs a bore" Cruzinimage piston is a 2nd oversize, 75.5MM
Hi
What do you think about the big bore kit 705cc?
Need the bore anyways, why not go something bigger, and its nod a bad price at cruzinimage, what else do I need then?
