I have another, very basic question...
could anyone confirm, that the colour of my turn signal wiring is normal.
I ask, because I keep seeing references to "chocolate" and "dark green" and in one case, Team Junk wrote that it was easy to mistake the "chocolate" wire for black!
Well, that's not true for my machine - not by a long way and yet, I am pretty sure this is an OEM loom (if only because all wires in the connector blocks colour match).
Anyway, my "dark green" is 100% not any kind of dark green I've seen before - it's sort of pale mint green and what I think is the "chocolate" wire, could never be confused with "black"
The pale green and "chocolate" (light brown) are common to the front and rear bundle (see pics) - so I assumed that this pale green and mid brown MUST be my turn signal wires.
But I DO have a dark brown (almost black) wire but only in the front.
I DO have a dark green wire, but again, only in the front
I also have another mid green wire, going to the headlight bulb.
With the pale green and "chocolate" wires hooked up to my indicators, with ignition key to "on" I get a solid lit (not flashing) right front turn light. Nothing from the other three and the turn switch doesn't do a thing.
I have 12v to the brown and brown/white wires to the indicator relay
I have 12v to both sides of the turn signal switch.
I am maddeningly confused right now!
See (even more) images of front and rear wiring
