Horn electrics
chinny1953
Cheshire
44EA3A33-FC7D-4887-90A7-DDEA8989EE1D.jpeg my son is customising his 79 xs650 and got a new switch for horn and high beam the wireing consist of red /white live to switch green horn button and black high beam button how is this connected to the bike cheers I’ve bench tested and it works but no luck when I’ve tried to wire to bike loom appreciate thoughts on this
For the horn, iirc, and off the top of me head.....
Power to the horn is a pink wire found in the stock loom, activated by pressing the horn button which then grounds to the handlebars to complete the circuit. Where the pink wire gets its power from would be the horn relay thingy....
Yes, the horn button provides a path to ground, so you will need to connect that green horn wire to ground inside the headlight bucket. There should be a couple multi-pin ground connections in there. The black wires feeding them run back to a ground connection somewhere on the main frame. The bucket itself is not a suitable ground connection because it's rubber mounted, plus somewhat isolated from the frame because of the greased steering bearings.
Hi chinny,
wiring the stock horn like they said will make it work OK.
Wiring a horn that's loud enough for a car driver to hear takes a relay.
I use a Stebel-Nautilus mini air horn. It comes with a relay that has a wiring diagram on it.
Ok guys horn sorted just got to figure the headlight now ?! Thanks for all the info also sorted custom indicators cheers :)
Seem to have done something wrong with headlight I have one wire comeing out of hi/lo switch does this go to yellow high beam wire also we’re would my low beam green wire go to make headlight come on when engine starts cheers again
