wildboar58
these are the pipes that came on the bike when i bought it .they welded a smaller diameter pipe in side the straight section to create backpressure.
these are the pipes that came on the bike when i bought it .they welded a smaller diameter pipe in side the straight section to create backpressure. View attachment 174539
i meant yes they will work. i think i would like to put on some glass packs and run them that way for now .i like the way they look.
Not having seen them, I can't weigh in on them. You probably should consider what you're using the bike for. Putzing around? Track days? You want the gases to scavenge quickly. Think of it like the garden hose. With no nozzle on the end, the water just sort of pours out. Put a nozzle on it and it comes out fast. There is a science to it. Too small and we can't push enough gas out.hoos racing has some that are mild steel .i can weld on my own tips .are those a good choice?
