1974 TX650A Restoration Project
Question for you guys.
Up to 850 miles on the rebuild, and the bike is generally running well. I thought I'd give the valve clearances a review now that the rebuild has broken in a bit. First thing to do was check the cam chain tensioner.
When I rebuild the motor I replaced the copper washer on the tensioner with one of the rubberized replacement units from Mikes. Found a ton of good posts, notably from @5twins on how these units evolved over time (Believe I have the type 'C" in my bike, if memory serves). Problem is, with the thicker washer, the adjustment instruction of "Set the end of the plunger flush with the housing" doesn't work, as the thicker washer pulls the plunger in, leaving the end of the plunger recessed slightly. So, I've seen advice here to adjust while the engine is running, and set the tension so that the plunger movement is ~1-2mm. Actually measuring this wasn't the easiest thing to do, so I took a slow-motion video:
Any feedback on this? Seem normal?
I never really measure the plunger movement, just eye it up. My usual routine is to tighten the adjuster until the plunger movement stops, then back it off until I get the small amount of movement I desire.
I recently checked the adjustment on my '83. I did so just before changing the oil with the motor hot. I found it too tight, there was no plunger movement. I attribute this to the fact that I most likely set it before with the engine cold. I know it's been mentioned here that it should be done hot but I always thought if it was, all the parts would be hot and expanded, so it wouldn't be much different than on a cold engine. But apparently, this is another of those cases where different metals expand with heat at different rates and amounts. The alloy cylinders expand more than the steel chain so if set cold, it can be too tight when hot.
So, lesson learned, I will only be setting and checking the cam chain tension when the motor is hot from now on. I've made this part of my oil change routine so the chain gets checked at about 1000 mile intervals.
Thanks @5twins. Good to note on the hot/cold movement. I believe my engine was warm when I took that video....I recall having to gingerly navigate the fins and adjuster cover. Did you watch my video above? Does that look like the level of movement you might target?
Yes, your movement looks good. As I mentioned above, I feel the best adjustment is had by tightening the adjuster up first then backing it off. You won't hurt anything by running the chain tight like that for a few seconds. With this method, you get the chain just loose enough, just a bit looser than too tight. In my opinion, you get the perfect adjustment this way.
I had that thicker rubber/metal washer in my '78 for a while but went back to the copper one. I found no difference with that rubber/metal one. The bike didn't run or perform any better and there was no less noise. As you've noted, the only difference was it made adjustments more difficult. I think the way MikesXS advertises it as an improvement is just a sales pitch.
:cheers:
Color (tank/side covers/headlight/fork ears):
Down to the million dollar question.....what to do about the paint. The paint was not in horrible shape when I got it. In fact, some of it could likely have been salvaged if properly prepped and re-cleared. That being said, I had 2 issues.....
1) As mentioned previously, this bike took a spill at some point. The tank had a crease and some dings in it, down to bare metal, the headlight and left fork-ear was a little misshapen and had some missing paint as well. So if I wanted this thing to look right, some sort of repair was in order, beyond just clear-coat. Some pics here:
View attachment 168837 View attachment 168840 View attachment 168841 View attachment 168839
2) As I'm sure lots of folks here know....Yamaha factory paint schemes can be a bit elusive. Most colors only existed for a single model year.... and while information on the colors can be found if you look hard enough, good luck trying to replicate them. For example, the TX650A in the US came in "Cinnamon Brown".
First coat- Custom Silver B/C PNT-00000-00-82
Second coat- Cinnamon Brown Candy T/C PNT00000-00-N1
Final coat- Clear PNT-65000-04-00
(From <http://www.xs650.com/threads/74-tx650a-cinnamon-brown.39046/>)
Those aren't exactly universal paint codes. And even if I could get my hands on those exact colors, I've got 40+ years of patina and fade on this thing, and there are visible differences in the color even between the two side covers. So a touch-up was going to be a tall order, especially with a unique color like this and not to mention I HATE paint and I'm not good at it, so I was planning to outsource this.
I shopped the job around a little and got a range of prices from ~$1200 up to ~$1750, which would include trying to recreate the stock color. Let's say bids on the lower end didn't inspire a lot of confidence... My concern on the high side was not just the money (although I was a little surprised there)....there's an elephant in the room here, and maybe you guys have thought it yourselves.... This is my first bike! I've got like 30 hours of seat time. I will say I'm a good rider, but something felt a little foolhardy about having a show-quality resto paint job on a bike that I'm still, frankly, learning on. So.....where does that leave me....
So.....at this point, I had a good relationship with my local powder coating shop having done my chassis parts and rims, as well as having access to my buddy with the vinyl cutter. So I started thinking about powder coating as a solution. The dings in the tank could be repaired with high temp epoxy, used like a heatproof Bondo. I started looking for color options.
View attachment 168843 View attachment 168844
I ultimately settled on a color called "Lazer Copper", which I think is in the spirit of the original. So off to the powder shop....
Similarly, I started taking a bunch of measurements of the graphics to send to my friend, to create the artwork.
You might ask why I didn't just buy some of the repro decals that are out there.... well, honestly, I think the ones Chris made for me are much better looking, but I also wanted to try a bit of an experiment. While there are a few criticisms of powder coating for body color, the most significant one to me is that you can't clear coat over the decals, because they can't stand the heat. I thought that if I could get the decals made in really high quality, high temp resistant vinyl (Oracal 751) then maaaaaaaybe, I could do my powder base coat, apply the decals, powder clear over them and I'd have the best of both worlds! Fast forward.....this didn't work haha. I wish I had done a little more R&D on it myself, but my powder guy tried it on a piece of scrap and said it wasn't working and just did the color/clear. Which I get, it's not his job to figure this out for me. But I think in the future I might experiment with this a little more, as I think there could be a really useful solution here and I'm not so convinced it couldn't be made to work.
Anyways....here are the decals I had made. Fantastic job Chris!
View attachment 168857 View attachment 168860
And as for the powder coat.....I went with a color called "Lazer Copper". When I got the parts back, I was stunned.....it looked way better than I could have ever imagined. And very true to stock, which is exactly what I was hoping for.
View attachment 168845 View attachment 168846 View attachment 168847 View attachment 168848 View attachment 168849 View attachment 168852 View attachment 168853 View attachment 168859
After I applied the decals (these are multi-layer....black first, then white, then in the case of the side covers, silver last). Takes a careful hand, but not too difficult. There's still a little flat spot where the dent was, but honestly I have no problem with that. And the best part is it cost $500, including the repair, plus the $125 I gave my buddy for all his help with the decals (and now I have a ready source for replacements ;-)
View attachment 168850 View attachment 168851 View attachment 168861 View attachment 168858 View attachment 168855
So.....I love the way these came out. Time will tell how the vinyl will hold up...it is exterior grade and meant for industrial applications, but it will have some rubbing on it from my pants and the bike cover, so we'll see how it goes. Honestly, if I have to replace it on the tank every year it's only 20 minutes and I have a ready source for new ones. Curious to see if there are cheers or pitchforks from this group hahaha.
Just added these to the 2021 Calendar thread but thought I’d post here “at home” as well. Few new ones from a nice ride around Martha’s Vineyard with my wife yesterday. Have about 1800 miles on my rebuild so far. One new addition is the snazzy luggage rack I snagged from phil240 that has been a huge game changer for the utility of this bike (and thanks to Randy/ @Machine for fitment guidance).
View attachment 175625 View attachment 175626 View attachment 175627 View attachment 175628 View attachment 175629 View attachment 175630 View attachment 175631
Damn that's a nice looking 74
:bike: looks better than the one I had and it was only a year old at the time
Great photos - your 650 just looks so at home in that environment.
Thanks Raymond! My wife and I spend a couple weeks out here every September so it’s been awesome to explore for the first time via motorcycle. I agree, she seems to be well suited to the locale :D (applies equally to both bike and wife, I suppose)
Thanks!! It’s definitely a work in progress but I was/am really happy with how it’s coming along
Not sure how well known this is outside our neck of the woods, but for those who don’t know, Martha’s Vineyard was used as the fictional “Amity Island” from the movie Jaws.
Man! There is nothing about that post I don’t like! Beautiful scenery, beautiful bike! A real calendar girl! ;)
