Jake650
Thanks for the advice 5twins. I'll post a want ad in the classifieds.
You can just run it direct to the h-light switch. Most people just bypass the RLU anyway. For that matter, if you run a light on/off switch, you don't even need the light relay.Question is do I need to include the reserve unit or can I simply run the Blue wire to the headlight switch?
And, the XS1100E.1978 was the last year that the right switch assembly had a headlight on-off switch in it. You might also be able to use one off another model like the XS500, 400, or 360, possibly the early XS750 triples as well.
1980 Special II has metal side covers that match the '78 & '79 Specials.I notice the 1980 does not have side covers over the air cleaners. I have a pair of 1982 covers off a Heritage Special gathering dust here I would let go cheap if they would fit on the 1980.
I knew a few here would know. The offer is open to anyone who has a need for them, prefer to sell to someone who actually needs the as opposed to someone hoping to make money by reselling.1980 Special II has metal side covers that match the '78 & '79 Specials.
Best wishes, Jake.
Look in the European market for headlight switches on the bars; they were fitted for several years after they disappeared from the US models.1978 was the last year that the right switch assembly had a headlight on-off switch in it. You might also be able to use one off another model like the XS500, 400, or 360, possibly the early XS750 triples as well.
