LastTracker Build Thread
Got the cover ready to polish. Doesn`t look that bad but it`ll look even greater all polished up and on eBait.
I got the frame back from my friend Jerry all welded up so today it was either rake leaves, pick up sticks and limbs, burn the brush pile, or make beauty-ugly plates. Plates won the toss.:shrug: The plates are just roughed in for now. I`ll polish everything at once so I only have to clean up one mess.:thumbsup: Next are foot peg/MC mounts and under seat electronics tray and figure out some kind of exhaust.:umm:
beauty plates 003.JPG beauty plates 006.JPG beauty plates 007.JPG beauty plates 004.JPG beauty plates 005.JPG beauty plates 001.JPG beauty plates 002.JPG
I took the frame to my friend Jerry and had him weld what I tacked together. Had to put this up on it`s wheels to see how I was going to change my mind. I did.:shootme: I`m on the fence about several things but at least everything align`s and nothing warped in the process.:thumbsup: Brat Tracker??:umm: Probably not. Any input or suggestions?:shrug:
View attachment 177087 View attachment 177089 View attachment 177091 View attachment 177092 View attachment 177094 View attachment 177095 View attachment 177098 View attachment 177100 View attachment 177101 View attachment 177102 View attachment 177103 View attachment 177104 View attachment 177105 View attachment 177106 View attachment 177107 View attachment 177108 View attachment 177109
Nice! Is that a Storz alloy tank?
Today I knocked out these folding foot pegs. They will get polished and fitted with Bates grips. This is what happens when you have no vertical mill and too much time on your hands. Final score; Phil 1- yard work 0.:thumbsup:
folding pegs 001.JPG folding pegs 002.JPG folding pegs 003.JPG folding pegs 004.JPG folding pegs 005.JPG folding pegs 006.JPG folding pegs 007.JPG folding pegs 008.JPG folding pegs 009.JPG
Today I roughed in the LH foot peg mount. Easy because the pattern is the same as my 1st tracker. RH will be a little different because I haven`t decided which MC I`m going to use. I also put the leaf bagger on the ole JD today.:doh:
foot peg mount 002.JPG foot peg mount 003.JPG foot peg mount 010.JPG foot peg mount 009.JPG foot peg mount 008.JPG foot peg mount 004.JPG foot peg mount 005.JPG foot peg mount 007.JPG
The mower-bagger deck belt broke yesterday :D and will be Mon. until I can get one, So I got the RH brake/peg mount made today.:thumbsup: It took a while but everything lines up and the start lever has plenty of clearance. I`m going to polish these tomorrow just to see what they look like. Who knows, I might actually like these without changing my mind. Or not.:shrug:
brake side mount 002.JPG brake side mount 003.JPG brake side mount 007.JPG brake side mount 009.JPG brake side mount 010.JPG brake side mount 011.JPG brake side mount 012.JPG brake side mount 014.JPG brake side mount 015.JPG
On a side note yesterday I was 73. Glenda saw me with the flat mounting plate and said "What did you do? make a Hip Replacement?":shootme:
That's one thing some people seem to forget. Anything you can make on CNC you can make on manual machines, but if you are willing to put in the time you can do it with files and drill press. If needed you could even get by without a drill press or drill. It's a matter of time and effort. Machines just save time.
Between here and dotheton I have seen some impressive work done with hand tools. Halfmile always seems to have a nice build.
Well so much for polishing everything all at once.:shrug: Polished the brake stay with black compound for now. T-6 aluminium requires a lot more prep to polish.:thumbsup: Braided line`s and banjo fitting will get here tomorrow and that should wrap up the brakes front & rear.
