Shift shaft chain guard
What about making that area a bit larger but then put a flat spot on one side to give clearance for the harness? Kind of a D shape at that end?
I immediately thought square. Like this...
But D is better.
Great, inventive work.
Just curious what "2 piece" gets you that just adding a groove in the original type doesn't?
I own two of these, one on each of my bikes. The advantage of two pieces is, the small piece that slides over and traps the wiring harness in place, doesn’t spin much due to the separation. Thus protecting your wiring harness from friction damage.
How would you go about attaching a delrin sheet to the original, where the rubber was? Or is there something more glue-able that can be put there as a replacement? Maybe shoe sole rubber and barge cement? I think the old barge would do it, no experience with the new blue version.
