So this all started because I have a 79 XL75, that I put a built xr100 motor in. 120 big bore, cam, ported, 24mm flat slide, tiny flywheel. It's a blast because it's so overpowered, but the suspension and ground clearance are terrible.
Enter the $75 CR80R. Doing a little reading on forums and plenty of people have swapped the XR motor into a CR. Gives you a stronger frame, better suspension, and a motor that is great for a play bike. It's a bit involved, like cut out the entire engine cradle. But I'm making progress.
