some wiring diagrams
Most handlebar mounted start buttons ground right to the handlebar through the switch frame. If you are using "some other" momentary contact switch yes wire one of the two contacts to a frame ground.
Like this?
Here is a set of Standard Wiring Diagrams mostly colored. Some of these may have faults so be aware. Jayel, Has supplied and converted these to a PNG image for us and the clarity is excellent
View attachment 135458View attachment 136328View attachment 184330 View attachment 125040 View attachment 116685 View attachment 116686 View attachment 116687 View attachment 116688 View attachment 116689 View attachment 116690
Go down to Jayel's post for diagrams of cable routing
Thanks for the posting the last image sealed the deal for my CDI unit , bk wire is ground 100% known, Bk/W has same continuity to capacitor as bk , seems like ground cut wire out to side stand and drawing confirmed that
It is a TCI unit, not a CDI............another thing. I notice you refer to the bike as 79SF. whatever your paperwork says the bike is an 80SG. Different carbs, (BS34's), Has an Factory electronic Ignition, (TCI), clip on seat and different taillight/number-plate light and speedometer
Hi have you got this in a PDF format you could send to me please
Yes I may have s few on my work computer.
You could just download any amount of them from the TECH area of this website.
TECH tab at top of page.
