For Sale - NEW FRONT GUIDE STOPPER
hooser
XS650 Junkie
IOWA
New front guide stoppers , $30.00 shipped in the USA. I worked with new MFG for over a year, to get these right. I asked gggary to check out, see his post. email me at gary@hoosracing.com if interested. Thank you.
The thread http://www.xs650.com/threads/new-front-stops-cam-chain-guides-beta-test-sale.56305/
Well, I have not heard any reviews on this ft. stopper but may email G.Hoos in the AM.
My real dilemma is I have a perfectly good 256 B -Type sprocket tensioner...and a 447 cam w/ 36 teeth had been running a 219T chain (106). Feel I should play it safe going to a Type C rear tension guide set up...if I can find a C-type assembly. Never the less I found a new NOS Yamaha rear guide for $80 or a Mike's version for $30. Which one of those two do I want? I want a C-type assembly as it looks like the hex cap I have.
My sproket tensioner, not because I found it in the engine, but I really don't see the functional problem with that sprocket from laying the chain across 4 teeth...seems to fit well.
A new forum group buy of Hoos Racing front guides will be available shortly. :whistle:
He just got in a new shipment So I asked nicely and got a good price for a bunch of them. :thumbsup:
I'll be selling about a dozen (keeping some for moi). Quality has been good, heard no complaints or problems on the forum from the first group we sold.
This is a straight replacement for the OEM factory front guide?
If so, put me down for one.
Also these can be miss-aligned. , verify your chain runs down the middle. There is some adjustment before you tighten the bolts. The cam also cam be miss-aligned and not centered. Which ether one can be Identified by one side of the guide being worn taking the edge off.
I was referring to the aftermarket guides? I would take an oem in a second.
At one point I thought there was a problem with aftermarket guides.
If this one is comparable to oem that's awesome.
Put me down for one! Timing couldn't be better, with my chopper motor torn down right now.
