De Paris
tachometer support
The relay on the CDI system is to adapt the handlebar kill switch. The stock system supplies 12v to the ignition when in the on position. The kill sw on a CDI system shorts the system to prevent spark. The relay uses the 12v from the kill switch to open the relay.When the kill switch is in the off position the relay closes the contacts shorting the CDI to stop the spark.
WELD ON TENSIONER
Hello
for or against?
How many MM of stretch is your hardtail? Really you should not need a chain tensioner with a hard tail if you have a properly sized chain. The saddle pivot point location will depend on seat size, tank location, peg location, height of the rider, and seat spring location.
Hello
The saddle measures 30 cm, and I 1.72m
I' weld my pivot mount there but move the seat back away from it. you don't want the pivot directly under the seat.
Hello
I have this angle, it's ok
thank you
