For Sale - Boat Load of PARTS -- Motivated Seller!
Would you happen to have the rear spring minting bolts? I just picked up a 74 tx500. Also looking for full front brake assembly from caliper to lever and a rear break lever. Thank you
Sending you a PM.......
Any chance you have a good crank? Also looking for good intake and exhaust valves. Both for a 78.
Hello
I am in need of right side exhaust
lower left side cover (#3)
Voltage Regulator Rectifier
Front fender
1983 Heritage Special
To 14305
Casey
Some of these parts I will practically give away. Everything for less than you'd think, even nice and valuable parts.
Small parts that weigh 4 ounces or less ship for $4.
Parts that weigh less than a pound ship for $5-7.
Heavy items that will fit in a Priority Mail Padded Flat Rate Envelope ship for $8.50 (starter motor, charging rotor, foot peg set, kick-start lever, kick-start gear, speedometer, etc.).
Bigger items ship for less than you'd think. I ship every day, and I know how to ship cheaply.
I ship with tracking, and I ship world-wide.
I've priced a few things, otherwise MAKE OFFER, and I'll provide condition details and take additional pics if needed. Please send offers using PM. Or, PM me and ask for me to quote a price. Make a counteroffer if you think my quote is too high.
I acquired a big cache, these pics are a fraction of what I have. If you don't see it, ask, BUT, I don't have any 1970-1973 parts in this particular cache.
Pics and descriptions will be updated, deleted, and added to as necessary.
Good working starter motors, $44 each, including shipping.
Good-looking kick-start gears, with good splines. $23 each, including shipping.
I have three of these Air Boxes in EXCELLENT & COMPLETE condition, with Good filters, Good boots, clamps, springs, crossover tube. $10 each OBO, plus shipping. For 1978-1979 Specials, and all 1980-1983.
Both of these covers are SOLD, however, I have more. I'll beat eBay prices.
Let me know what condition you are looking for -- something nice, or if a little rough is okay.
They changed a little over the years, especially the the Left-side cover, so let me know what year you need.
Clutches, complete, or will part out. Both 7-plate (1974-1979), and 6-plate (1980-1983). I will beat eBay prices on complete clutches or clutch parts.
Triple trees, complete or will part out.
Everything in pic has good splines.
Shipping a brake pedal costs $8.50. Will sell brake pedals for as cheap as $4 plus shipping for a perfectly functional but scraped brake pedal. On up to $8.50 for a pretty nice-looking pedal.
Have an early straight-arm kick lever, and a later bent-arm kick lever. Good rubbers, and will clean up. $12 each plus $8.50 shipping.
The shift pedal in the picture is SOLD. I might have a rougher-looking but fully functional shift pedal with good splines for about $10.
LEFT and Right complete calipers for rebuild, no damage, usable brake pads, good bleeder screws and bleeder screw seats, all threads good. Condition of pistons unknown. LEFT-side caliper has good paint, and is $79 shipped.
The RIGHT-side caliper in the pic is sold, but I have another one, in equal condition but with better original paint, for $35, shipped.
All tubes are 35mm. No rust at all on one of the sets. Minimal rust on the inner tubes on the other two sets.
The rear wire-spoke wheel is SOLD.
The front wheel is SOLD.
These are the only wheels I have. Rim edges are all good, with no tool marks. All bearings are good. A little rust on the wire spokes, a little rust on the chrome-steel rims, not bad.
$35 plus shipping for the mag wheel. The mag wheel will ship for between $20 and $30, depending on how close to Texas you are. The rim edges are good, with no tool marks, and the bearings are good.
Small selection of the gauges I have. The top two clusters are pretty nice, with GOOD DAMPERS and GOOD CHROME BUCKETS. All work, but some are a little wonky -- might settle down with regular use? Ask. I am motivated to sell these!
Small selection of the carbs I have. No compete BS38 sets, but I do have a complete BS34 set.
I'm going to toss the diaphragm slides, but the needles are good. I have just about every carb bit and piece that there is.
Good BS34 clamps.
Front and rear brake rotors. I HAVE MORE. I'll practically give you a somewhat rusty rotor that just needs to be blasted or hit with a wire-wheel.
Small selection of 1974-1983 headlights and parts that I have.
Disc brake swingarm (left) and 1974-1983 drum swingarm (right). I have more 74-83drum swingarms -- slight changes were made to them over the years, but they all interchange. These will ship for less than you'd think -- give me your zip code for a shipping estimate.
These have to go! Straight, no dents, good chrome, just dirty. Make offer! I also have earlier year rear fenders. FRONT FENDER SOLD.
CHAINGUARD IS SOLD.
The inner rear fender on the right is for for 1978-1979 SPECIAL models (SE,SF, and 2F), and all 1980-1983 models.
The inner rear fender on the left is for all 1974-1977 models, and 1978-1979 STANDARD models.
Both are nice, with good grommets. $5 each plus shipping.
The fender seal at bottom right is $5 plus shipping.
With or without 1980-1983 tail light! Must go!
TESTED on my properly running TCI XS650, and GUARANTEED for 30 days. In my experience, if a tci works for 24 hours, it will work forever. 6-pin for $85, shipped, and 7-pin for $90, shipped.
TESTED on my properly running TCI XS650, and GUARANTEED for 30 days. In my experience, if a reg/rec works for 24 hours, it will work forever if you treat it proper. $20 shipped!
Nice chrome. I have more. At least one pair is completely straight. I'll give you a pair that is very slightly bent at the ears, that you can straighten and the bend will almost completely be hidden by the big stock headlight, for practically free.
Good stuff.
All of the splined brake pedal pivots are SOLD.
Brand-new aftermarket. Cheap.
Used oil cooler for cheap, and some brand-new parts.
The brass BS38 carbs linking connector plate is SOLD.
I have more and better alternator covers. OIL FEED TUBE IS SOLD. CAM CHAIN TENSIONER IS SOLD.
All of the "650" emblem points covers are sold, but I have a couple of near perfect plain points covers (without the "650" emblem).
Got axle spacers? I have more and better axles, especially front axles -- Depending on condition, I'll practically give you a front axle for free.
THE "TOP HAT" SPACER (center of picture) IS SOLD.
$35 PLUS SHIPPING. Both petcocks are included, and look good. Rear damper is included. Will ship for between $20 and $30, depending on how close to Texas you are.
One dent on right lower front...
...and a small ding on the left side. Paint is not bad, just very dirty. No fuel residue inside, but the inside has some rust and crust -- this would be an excellent candidate for putting dry wall screws inside and tumbling it in your dryer. Little work, and you've got a nice tank.
PLASTIC side covers and emblems. ALL STRAIGHT, NO DAMAGE. $5-10. I only have right-side covers.
I ALSO HAVE A LOT OF METAL "SPECIAL COVERS", BOTH SIDES.
The top emblem is very nice. The middle emblem is very nice, just needs the background black paint, or remove all of the remaining paint, they look good that way too.
The middle chrome cover is nice.
Cover or emblem, $5-10.
MORE TO COME. I have only gone through about half of what I acquired. IF YOU DON'T SEE IT, ASK.
I need 2 breaker base plates if you still have them
I just found this post. I'll have to check it tomorrow. I'm interested in, Air box w crossover 1980
Bs34s and related possibly. Tank. I'll read the whole post tomorrow. I've been desperate for resonab!y priced bs34s. Even just left frame the detent ball housing is cracked.
Sending PM.....
Do you have a good stock rebuildable Master Cylinder / Brake Lever Assembly for an XS650SH? Need to replace on on my Brother in-laws bike to get the left hand threads for the mirror so we can put the factory mirrors back on.
Hey Shelby, Dovi61 here. I could use one of the auto advance housings and the 3 small screws that go with it. You could probly send it thru the mail or if I have an address I could send you a cheque and a self addressed envolope. That is if they will fit my 79 xs650. Let me know how we can do the transaction.
Thanks
Thanks
PM sent..........
Similar threads
Sold / Found / Inactive - ON HOLD (1971 XS1B parting out)
  • Price: $5 - $400
  • world-wide shipping
Replies
3
Views
282
  • Aurora illinois
Replies
16
Views
1K
Sold / Found / Inactive - 72 XS650
  • Price: 6100.00 U.S.
  • Brandon MB.
Replies
1
Views
226
