Nice one, Jim. What do you use to put the 'extras' in? Powerpoint?
Just plain old Microsoft Paint.Nice one, Jim. What do you use to put the 'extras' in? Powerpoint?
I used to run a dual boot laptop with Windows 7 and Ubuntu. Used GIMP on the Ubuntu side. It's a pretty good photo editor.Maybe my 9 year old, bulky, heavy and failing Ubuntu laptop should make way for a Windows doodah. Bah ....
2 5/8"I'd like a measurement of the narrow end of the mount. I estimated it at about 2 3/4 of an inch
Ah well I made it a little wide2 5/8"
Well, that's disappointingWon't hurt a thing. After welding, no one will notice.
If at first you don't succeed...Well, that's disappointing
I've got one plan; Turn key, and kick. Beyond that I'm swampedI don't recall what exactly happened but it went something like this..... I had some floats sticking or some shit causing my carbs to leak gas. Using the electric starter a wire shorted and smoked a wire and with the gas around....yeah things got a little hairy. Those starters draw a lot of amps. I understand why people use them but I'm still healthy enough to just kick mine. For wiring, I've been tearing it all out and starting over. Really can be time consuming but not difficult, off the battery to a fuse box. From the fuse box to what ever. Replace old filament bulbs with LEDs if preferred. They sell led turn signal relays which are nice. When you go to start this after years, be outside. Haha! Rusty gas tank? Oh yeah had to edit, if you need to check for spark, have a good ground. Like a jumper with a good clamp from plug to ground. Electronic ignition will fry easy!
Consider yourself lucky you didn't take a fancy to a English or German bike.Ya know, I thought I was in for a budget friendly bike build when I saw the low low price of the harness, unfortunately every other part costs just as much.
If H-D stands for Hundred Dollars the XS must mean "In XS of $650"
I guess now that I've got nothing better to do, I could tear down the carburetors, with my luck I'd end up ruining something in the process.I was going to mention earlier (and I should have) that it's rather foolish to attempt starting one of these (or any bike for that matter) that has sat a long time without first having a look inside the carbs to see if they're all gunked up. If they are, an attempted start will likely make things worse, sucking gunk all through the carbs and plugging them up worse than they already were, lol.
