What is the hub width on an XS650 Front wheel?
schachterle
What is the hub width on an XS650 Front wheel? Is the drum the same width as disc? What is the actual measurement?
- whatever the width, its the same for disc or drum - you need howevever the SR500 bracket to mount the drum
I'm looking for the width side to side of the hub. bearing side to bearing side. I'm not sure how to explain
I measured a front mag wheel and spoke wheel and got 96.3mm and 96.4mm between the outside of the bearings. Both were disc.
I also measured a rear mag wheel an that came in at 134.2mm between the outsides of the bearings.
Hope that helps!
