18 or 19?
lakeview
XS650 Guru
XS650.com Supporter
XS650.com Supporter
S-W Ontario
20200827_194358.jpg OK, I am just putting a rolling frame together and need to know whether there are 18 or 19 ball bearings in the steering stem races and is the bottom number the same as the top?
I vaguely recall seeing a post saying the number, but darned if I can find it.
I know about the tapered bearing conversion and have done several but not for this frame.
That is 19 for each end, thank you Gary. I did not think about looking up fiches.
What!? No roller bearing upgrade?
It isn't necessarily an upgrade. The ball bearing steering head steers quicker. So, if that's what you want, then going back to OEM is the upgrade.
Just for my understanding, how does the style of rolling elements change the "speed" of the steering? Not disagreeing but just looking for knowledge!
While on the subject of ball bearing steering head. Does anyone have the spec. on the diameter of the balls in mm's?
I know decades ago I was replacing the balls in the steering head of a RD400 I was shocked at the price they were asking for them, seem to recall something like $1.00 each. Not bad if you only needed one or two but when buying 38 it starts adding up quick!
Especially when a quick Google search can find 4 mm balls for $6.50 for 100! Just a wild guess on size don't go by that unless confirmed by someone with one in hand!
Supposedly, the ball bearing steering head has less contact area and less friction. They also provide better steering feel and feedback. In the case of the XS650, I'm sure they're cheaper than the tapered roller bearing steering head. The R1 came out with the ball bearing steering head, back in the 90's and I don't believe that was done for economy.
The tapered roller bearing spreads the load much better and lasts much longer. The XS1100 came out with tapered roller bearings in 1978. My guess is because the bike was so much heavier than the XS650. It also had a higher price point.
For the record, I wore out the OEM bearings in my XS650.
See what Andy said.
All my 70's dirt bikes were equipped with ball bearing steering stem bearings. I got use to setting them as a kid. That was after learning very young how to properly set skate board wheel bearing tension. BMX bikes and road bicycles used ball bearings throughout. Took many wild rides on ball bearing equipped speed devices. :yikes:
Ball bearings just dont scare me enough to change now on a simple XS650.
-R
Angus, you may be aware of this, but the races get dimples in them and then the steering feel is a detent, usually at the centered point. Replacing the races is the fix.
Um that's 1/4"
Ie your hardware store has them in stock.
Bicycle shops keep lots of ball bearings on hand.
Thought it was odd that Yamaha would use a non-metric size, maybe 1/4 inch is just a more common stock size?
6.3 mm is less than .002 inch off of a 1/4 inch size.
Yes, that probably explains the 5/16" balls used with the clutch pushrod. The parts diagram actually lists them as 5/16" too .....
That is exactly what had happened on my 77D, the race had become so indented that you could let go of the handlebars when the front end was raised and it would snap back into position. It made the bike road wild and hard to handle. Changing to tapered bearings transformed the handling. Not that there is anything wrong with ball bearings when they are in new condition.
Pete, then gave me the definition of that phenomenon.
