1970-1976 brake master cylinder question
louis
Newcastle, Australia.
My master cylinder leaks from the bottom of the threaded cap if the bars aren't dead straight, should there be an o ring at the bottom of the threads? And if so, what size and thickness is the o ring?
Thanks
I think your problem is obvious.
There is a rubber bellows inside the cap I pictured. All caps need those. It keeps air/brake fluid separated.
