The dimmer switch has two functions listed in the right of the matrix. Explain what they do.
Power flows into the dimmer through the blue/black wire. The two settings of the switch complete one of two possible circuits that result in varying voltages (or is it current?) being sent to the headlight, with the green wire having a higher voltage in the yellow wire. Something like that?
Feedback loops really need a fresh brain to puzzle through
Definitely, I find it much easier to think of current flowing in only one direction, too bad it doesn't!
Wouldn't this solve the issue of the powered loop and retain the park option
I am certainly no expert on this, that has been
well-established here! However, I don't think this will work due to the type of fuse box I am using. It is not capable of multiple "inline" fused circuits. Power goes in and is distributed through a gang, with each outgoing connection being fused. I believe that setup would also subject the main 20A fuse to a short in the taillight/gauge, which we are trying to avoid. The real problem is how the headlight switch and ignition are both supplying power to the blue wire.
I'm not sure what diagram you modded to make yours but the ignition switch rendering is not correct for your early model.
The switch blocks I have are for a later model, this thing is a Frankenstein!
2. Parking light on but without Instruments lights on: The thick Blue wire from the ignition switch should feed directly to the tail light and preferably via a fuse. This requires making a cut in the Blue wire to separate the Park switch from the Headlight switch.
This is the solution I like the best. It might be nice to have the taillight on as a park indicator. It would also only turn on the meter lights if the headlight was on, which seems logical to me. Here is an updated diagram:
I'm glad we ended up working this out, as the fuse box used above is going to fit much better in my setup. I got in a fight with some sheet metal yesterday and came up with this "structure" to mount most of the electronics in front of the battery box:
