QWERTYMage
The Apology
1st, I'm sorry I'm sorry I'm sorry for ANOTHER charging system question. I have no doubts that the answer to this question does exist somewhere in this board, but it's like finding a needle in a haystack. I have read through a few posts and there is SO MUCH info that I am more confused than when I started and it's only getting worse. My brain hurts now. Being that two different stator types exists has made this even that much more confusing.
The real question.
I have a stock '75 stator. I am testing to see if the green wire to the positive brush is damaged/shorted, etc. with a multimeter.7
When I test for continuity of the green wire (to make sure the wire is not broken and current does flow through it), I do get continuity. I test from the brush and both sides of the regulator connector block. I get .1 ohm resistance
When I test to make sure the green wire is NOT shorted, I have the power OFF and test at the connector block. I get no short (no continuity) to ground. I test for ground at multiple points (at my battery ground location, on the negative brush holder, and the engine case left side)
For this type of stator (The early one used with points), do these tests indicate a healthy green wire?
The reason I'm testing the wire, is my regulator isn't regulating as it should (charge went past 17v) and I am trying to troubleshoot my wiring before I send my reg/rec in for repairs (Oregon Motorcycle Parts reg/rec) to see why the reg may have gone bad. FWIW, OMP Tony has been very helpful.)
The real question.
