1977 yamaha 650 d restoration files
Upper Trip aluminum clamp finishing
  • paint stock
    Votes: 2 20.0%
  • polish aluminum
    Votes: 8 80.0%
  • Total voters
    10
  • Poll closed .
two issues so far, need some advice,
1. plugs keep getting carbon fouled, not so bad they wont fire, but I would like them to be cleaner, is this just an air mix issue? if so how do I dead cylinder this if the coil warns not to disconnect one side?
2. have a small oil leak coming from the neutral bolt on the top of the crank case the 7/8" bolt next to the oil filler, this is a very slight leak. can I remove this bolt and just find a copper washer to put there? or will I disengage something from the tranny if i pull it.
If that's the bolt for the neutral light, there's a gasket that needs to go underneath it. It's just a small sensor switch so it's ok to remove it. You have to detach the neutral wire before you unbolt it though.
