slayer123
i just rebuilt the top end on my 650 and was ready to start the engine. i hooked up the battery to ground on the starter, and the positive wire to the brown wires on the two coils, and the left coils orange wire to the grey wire on the left points, the right coils orange wire to the orange wire on the right points, and then connected both black wires from the condenser to the left and right coil wires too. i have a link of the wiring diagram i used to start it minus the stator and the rectifier. i didnt hook up the stator or rectifier so the battery wasnt being charged. i had spark, it was blue. so i finnaly kicked the thing over and it was running good and i was trying to tune the carbs on it then the on/ off switch i wired to it bumped the frame and started sparking and the starter engaged. nothing got damaged but now i have no spark at all. i did notice the battery was at about 9 volts today too. and i did notice when i pulled the throttle the thing would rev up but than after a while when i pulled the throttle the thing would bog down and back fire. did i fry something? when i use the test light on the coils it lights up along with the condensor too. i do have an extra set of points and am going to hook up the regulator and stator too. any advice? i bet it is something simple! Thanks!
