livetoride21
Hi Everyone, I have a 1978 XS650 that I just brought back to live after being stored away for 31 years. It was stored away after the owner ran the bike low in oil, and then heard a knocking noise the next day.
What a surprise, I have a strange tick/knocking noise. I'm afraid it could be a rod bearing, any ideas?
I adjusted the cam chain tensioner and it appears to be adjusted fine now, but could it still be cooked on the inside?
Also could the valves being out of adjustment do this? (I'm going to check them tomorrow)
lastly, I've checked and have very good compression 150lbs, so I'd be surprised if there is any engine damage in the bottom end without in turn damaging the cylinder walls or valves.
In my experience, when a motor runs low in oil, the first thing to go are valves / compression. then crank.
