Now, time for some more updates.
I replaced my original brake line with a braided stainless one from ANPlumbing (the old Earl’s) and VERY CAREFULLY adjusted the rear brake rod and now the rear brake works perfect. I thought the 14mm master might make it too wooden but I’m very pleased with the feel and won’t be making any more changes to the brakes.
BUT, on a couple of rides I noticed just a hint of clutch slipping in 5th going up hills so I also replaced the original clutch springs with some HD Vesrah springs while I had the bike in the basement for the brake line. Clutch slipping solved.
I have ridden it to work a couple of times, maybe 200 miles total, and figured I was done fixing things until last Friday. As I was pulling off the highway and reached the bottom of the off ramp it sputtered and died. I tried the starter button and just got a click. I tried kicking it and it fired up for a few seconds and died again. The instrument lights, and all the other lights for that matter, were pretty dim so I assumed I probably had a charging issue and ended up pushing the bike about 1-1/4 miles to work where I had access to some tools and more importantly a DMM. After some poking around it was pretty clear it WAS a charging issue as the battery was dead (9.8V) and the rotor measured 0.7 ohms so definitely a dead rotor. I was surprised as after first bringing the bike back to life it had 14.5 volts at the battery so I assumed the charging system was in decent condition. I charged the battery up during the day and rode the beasty 36 miles to home with the headlight disconnected and the battery still had a pretty good charge when I got there so I could have gone quite a bit further should anybody have wondered how far you can get on a dead charging system.
I looked through Dad’s stash of old parts and found five rotors, three of which measured above 5 ohms and were in useable condition. Rather than just replace the rotor I did some poking around the forum and there was a lot of advice to check voltage at the brown wire and check/clean connections before just replacing the rotor and, sure enough, the voltage was off by about 1 volt so time to clean some connections and the ignition switch. The first connector I checked was at the voltage regulator and the male connector on the red wire had pretty much turned to dust and the others were pretty ugly. (The other things in the pic are the bent up paperclips I used to remove the connectors from the plug, one for male and one for female.)
After replacing the connectors on the red wire and cleaning up pretty much every connector on the bike plus the ignition switch the voltage difference between the red and brown wire is less than 0.1V so all should be well. Even if the ignition switch contacts weren’t all that bad it was still worth cleaning it as the grease had turned to tar and now it works SOOOO much better. I put the rotor in the lathe and polished up the contacts real “purdy” and resistance is 5.3 so I should be good to go. I’m in process of putting everything back together and hope to have it finished shortly, maybe tonight if the stars align.
