Britman
I spent the afternoon wiring in a new blade fuse box. Half of the old glass fuse holders were broken. The reserve lighting unit is disconnected and on the workbench and blue/blk and blue/yellow wire connected. The turn signal canceler unit is keeping it company and with a newly installed automotive two pin flasher produces signals that work great. I also have a horn, tail light, brake light, and a starter that spins like new, rare for XS I gleam. There however is no headlight, neutral switch, or dash lights. The bike is nowhere near being able to be started and I am testing with a outside jump battery. What I find confusing from reading threads here and trying to make heads or tails out of the wiring diagram is the headlight safety relay. I presume my headlight should not come on unless the motor is running and relay is triggered with power from the alternator. (Should this affect the dash and neutral light also, or is there another issue?) Can the HSR be bypassed and I would truly like to install a real damn headlight switch. What can I say, I am old as dirt and like things simple. Any suggestions or hints from those here who understand these relay layden systems and have knowledge on how to simplify would be greatly appreciated.
