THANK YOU Superjet! I won that auction for $39.00. I was looking on ebay for springs but didn't see these there. So again....thank you.
Are you considering converting to "elephant's foot" adjusters? Plenty info on this site - if the concept is attractive to you, it's a good time to do it when everything's disassembled anyway.I have one exhaust valve that looks questionable. The end has some slight pitting and it has some pitting on the side. Should I find a replacement for it or will it be fine to use?View attachment 134535 View attachment 134536
I wanted to post pictures of my tank. It had a nasty paint job and the tunnel was rusted. Inside was pretty rusty too. I used air craft stripper to loosen the paint. The paint washed right off with a garden hose to expose rust under the old paint. I neutralized the stripper in three baths of water and baking soda then used a scotch brite pad on the rust. The rust just fell off with hardly any pressure. Looks like it fresh from the factory before paint now. I wiped WD-40 all over it and sprayed the inside too. Now I just have to save $400 to have it painted. Anyway, here are some pics.
View attachment 133539 View attachment 133540 View attachment 133541 View attachment 133542
Yeah, I've got Virago adjusters in mine, mainly because I've never had any reason yet to remove and disassemble my engine. No doubt they and the stock OEM adjusters do the job; the advantage (as I see it, anyway) with the elephant heads is that they are less likely to lead to the concentrated wear and pitting over time that can prevent repeatable, accurate clearance measurements. I would never yank my engine just to do the elephant feet; it would be an opportunistic move when the engine was out for a more compelling reason.aldo5468, I did read trough a few threads on the elephant foot adjusters. I think for my build I will go with the virago adjusters and call it good unless I find a good deal on new stock adjusters.
