The seat I have is in great shape I just don't like the way it looks. It's too wide and I don't like the double tier.
Thanks for the fork oil info. it seems simple enough I will go pick up some oil tomorrow, how will it change the way the bike rides?
I don't know where the air leak could be on the carbs. I put on new carb holders, or boots or whatever they are called, but I guess it could be the pods. It's not a major problem and for now I'm just going to enjoy riding while I can.
Hi shade,
you can't do much about the seat's width because it follows the line of the frame.
You can remove the cover (if you're careful with that you can sell the cover to Drew?)
Then re-shape the seat foam to a flatter shape and get a custom cover made for it.
If the old fork oil hasn't leaked away over the years you won't notice any difference in the handling unless you use a different weight of fork oil.
If there ain't any oil in there you will have noticed the forks still bouncing a quarter-mile down the road from the bump you hit.
Fork oil will fix that.
Mind you, if the forks are dry and the fork seals are shot, the new oil will leak out and contaminate your front brake pads. BTDT too. It's not a good thing.
My latest exhaust fireworks weren't an air leak after all; cleaning the left carb's slow running jet fixed it right up.
Pods, you say? What kinda pods, eh? There's only two kinds:-
Uni-pods, which work OK.
All the others, which don't work too well at all.
