tonyc
XS650 Guru
Bearcat I have thought seriously of running one 36mm VM carb for my next project. If I do Iwill build a plenum located behind the frame center post. It will have runners to the intake ports.
Don't want his advice and never needed that advice. Anyone on this forum could figure out going back to 2 carbs would work. So there's not terribly insightful or innovative there. Can't even understand his rambling like, " looking at your manifold, drawing air from the opposing filter" ??? Didn't understand much about the intake at 1st and know just a little more now. Just wanted to see if i could fix what I had. My first build and it's not for racing, just for fun. I thought about scrapping it many times, been encouraged by to many people not to give up on it. I will run 1 carb, may or may not be the same intake, we'll see? I'll call it my "Jacked Up 2 Into 1 Intake", in his honor.
No doubt there is a better way and I'd love to see you work on a different design.Bearcat I have thought seriously of running one 36mm VM carb for my next project. If I do Iwill build a plenum located behind the frame center post. It will have runners to the intake ports.
Tony, Hoffman,,, how about a Marvel Schebler updraft mounted below that plenum?
Reviving an old thread:
...Also, the air velocity through a single carb nominally doubles, correct? It's not necessarily more restrictive than dual carbs of the same design, or am i off base here.... plan is to try a 34mm TM flatslide.
...What's your thinking on that tract length?
