1. Dismiss Notice
    Dismiss Notice
21 inch Mini Brake Drum Chopper Wheel Locking up
Discussion in 'The Garage' started by Surfrat28, Apr 18, 2019.
  1. Surfrat28
    Surfrat28 XS650 Enthusiast
    Hey guys,
    I am adding the final touches to my chopper build of a 1979 xs650SG and I have added a springer front end and ended up getting the 21" mini brake drum chopper wheel from lowbrow. I have it set up and trust me I know that this brake doesn't have great or little stopping power. however, I keep running into that it wants to lock anytime I touch the brake. Do I need to make my own torsion spring to fix this or did I miss out on a part I could have bought?? Any help would be awesome to help me get this thing is working condition.
  2. azman857
    azman857 '80 XS 650SG Rider XS650.com Supporter Top Contributor
    How skinny is the tire?
    gggGary likes this.
  3. Surfrat28
    3.25 Avon Speed master
  4. gggGary
    gggGary I'm listening, change my mind XS650.com Supporter Top Contributor
    pics of the set up? Have you looked inside the drum? how do the shoes look, lots of brake dust? how does it act in the air hand spinning the wheel up to speed then braking? Hint a 6" buffing disk on a drill makes a good tire spinner upper.
  5. gggGary
    How, where is the wheel end of the cable clamped?
  6. Surfrat28
    I don't have a picture of it up close its still work in progress. Everything is a brand new set up. When braking it locks up and compresses the whole springer front end. I could loosen the cable but it doesn't seem like it wants to retract once pulled.
    gggGary likes this.
  7. TwoManyXS1Bs
    Is this the wheel?
    https://www.lowbrowcustoms.com/cycl...ake-drum-chopper-wheel-3-4-inch-bearings.html
    You'll probably want to disassemble it and lightly grease the brake cam.
    Also lubricate the front brake cable.
    If the shoe springs are too weak, you may need to fashion up some sort of external return spring, connected to the brake lever. Some bikes use a spiral return spring that wraps around the brake cam boss, like this return assist spring (#36) on the XS1.
    This has nothing to do with your brake lockup, but you may want to review your brake stay method.
    http://www.xs650.com/threads/springers.53186/
    gggGary likes this.
  8. gggGary
    What springer is that?. Springer has lots of pivots, movement can amplify the the brake action unintentionally, any sloppy joints? Just riffing. may need to play with length of the arm the cable attaches to to adjust the ratio.
    I've heard even late model Harley springers are maintenance pits, the pivot bushings need replacement "frequently".....
  9. Surfrat28
    Its a DNA narrow 22" springer. The whole front end including the wheel and tire are brand new.
  10. gggGary
    check for slop anyways, (a little birdy)
  11. Tomterrific
    Tomterrific XS650 Junkie
    Does the brake sometimes not work well and sometimes locks? There could be grease or other liquid on the shoes. I fixed brakes on a car and a pickup that did just this. The car had leaking brake fluid and the truck had grease on the shoes. In my cheapskate experience you cannot merely clean the shoes, they must be replaced.
    Tt
    gggGary likes this.
  12. gggGary
    Check that your neck bearings haven't "settled in" and need re-adjusting.
Share This Page
