If you meant rocker arms that could wiggle, then yeah, you got it. View attachment 198729
If you can wiggle a valve, you got serious problems...
Haha yes definitely rocker arms.
Which fuse is open? My Heritage Special blew the main fuse twice before the rotor shorted and drained the battery all the way flat.blown fuse again
That's most likely the clutch pushrod seal or the countershaft seal. It could be that 36mm nut has come loose.something leaking from left side cover
That 20A fuse you blew now for the 2nd time is the main fuse, so you may have an intermittent short going on somewhere. If it blows again, you should probably start investigating. As I'm sure you're aware, these bikes tend to vibrate a bit, lol. Over time, that can chafe wires and rub bare spots through the insulation. That bare spot might touch ground intermittently.
Going back to your earlier post about the plugs, if you start the bike cold using the choke, that will blacken the plugs. It usually take a little riding to burn them clean again so you may want to look at them again now after your ride. That dark one may have burned itself clean.
It's hard to say about the plugs from that view. You need to look down inside them, at the bottom part of the porcelain. You want to see a ring of color down there, coming up maybe 1/4 to 1/3 of the way at most .....
The top part of your plugs look good, all nice and clean, and white or lightly colored porcelain. But like I said, the real "tell" is how far up the "smoke" or "mixture" ring is on the porcelain.
Have you re-jetted at all? With BS34 carbs you really need to when any change to the intake or exhaust is made.
Well, since the BS34s come set up so lean from the factory, it's said that bumping the mains up one helps even on a totally stock bike. But, with your adjustable Canadian needle and (most likely) the matching needle jet, your midrange is probably a bit richer than the U.S. BS34s. So, one up on the mains is probably good for now. You might also want to richen the idle circuit a little. You can do that by reducing the air jet size. This will make it a little richer but not as rich as changing the pilot jet would. You could reduce it to a 132.5 or 130.
When I got my '83, I thought it was completely stock. Upon closer inspection though, I discovered that the P.O. had drilled extra holes in the muffler end plates .....
This small change was enough to throw the carbs off some, making the already borderline too lean settings even leaner. I "fixed" it by going up one on the mains (to a 135) and reducing the air jet 2 (to a 130). Eventually, when I got around to changing the exhaust and installing pods, I did increase the pilots one (to a 45), the mains another one (to a 137.5), and bumped the air jet back up one to a 132.5. The 130 air jets in combination with the 45 pilots proved to be a touch too rich. Once you increase the pilot jet size, you should no longer need 3 to 3.5 turns out on the mix screws either. You should be able to run them somewhere in the 2 to 2.5 turns out range. Mix screw setting will have a big influence on how far up the porcelain the smoke ring climbs.
That outer edge at the top of the threads will always get black like that. Your plugs look good. The ground strap is burned clean and gray in color. If it was all black, that would indicate a rich condition. But you most likely wouldn't see it all black without other parts of the plug being all black too (like the porcelain). Your strap is burned almost completely clean, A richer condition would have the black climbing up higher on the strap and higher on the porcelain in the center. Speaking of which, you didn't mention how your porcelain looks down inside the plug. Is there a ring of color around the bottom of it? Not rising up any higher than 1/4 to 1/3 of the way? That's what you look for.
On the Special models with the multiple fuses, the best place to tap in for a voltmeter is off the brown wire that comes out of the ignition switch. Any other place will have the signal going through 2 fuses and many wiring splits. You will lose a few tenths of a volt on the reading compared to what the battery is really at. I add a brown pigtail wire off the ignition switch plug .....
