Kick start shaft has also been modified to allow 100% engagement of kick gear onto the dummy 1st gear. Standard XS650 only engages about half way across which is fine for a stock motor, but can lead to problems with big cube engines. It causes first gear (countershaft gear) to wear unevenly, and even lead to cracks between teeth.
Quaife 1st gear damaged by kick starter- has a small crack at base of gear tooth
Because the dummy first gear in this setup is sitting further to the right side than standard, I only had to make the kick gear slide across a little further to achieve 100% engagement.
Kick start shaft with the flange faced back to allow the gear to engage further:
