XS650 Model Identification/Year/VIN, Workshop Manuals, and Other Information
650Skull
Cockytoo
FNQ Australia
Model ID......ID Charts........Online Manuals, (PDF)
Colored for county/continent variations.
Please contact me if you have any information or variances that differ from chart.
original chart kindly given to me from, (link), THEXSCAFE
** PDF. All Yamaha Model/Code list No's From 1960-1989.........Bottom of post #1
*CARB GUIDE; Post #7
Online manuals
ThexsCafe
Biker.net.......Scroll down left side to XS/TX 650 Manuals
Aug 77 to July 78 Production Date.........the Aug to July is not set in stone, sometimes there can be a month either side of the Aug/July
Frame Changes
1970 XS1-1973 TX.............................1974 TXA-1979 F: Standard..............1978 SE-1984 SL: Special
Engine; Con-rods/Pistons
Mid year change; XS1, (256), European, (553), US & others, (447), Con-rods/pistons in relation to models,
Use the Model code from the chart and cross reference with the ID chart, (in purple),. All European Model codes on the chart are 553 engines, corresponds with all European model codes on the ID chart, (in purple), from 75 till 82.
1, 447,553,265 Rods Pistons models b.jpg 447,553,265 Rods Pistons models 2b.jpg 3_stock_rods copy 1.jpg
Factory tool kit on my 80G
70-73 Triple Tree Differences
......By Dogbunny
https://www.xs650.com/threads/1970-...differences-identification.59575/#post-756976
1970 XS1.....Code 256.......Vin S650-000101 to S650-006686US,
Candy Green
US, Canada, Australia, Japan, Other
Points Ignition
1971 XS1B.....Code 256.....Vin S650-007101 to S650-025383
Candy Orange
800x600xs1b.folder2.jpg YAMAHA%20XS-1B%20Isle%20of%20Man%20.%20Ramsey%20.%20DR%20Jean-Louis%20Gayot%20%A9.JPG
1971 XS1F.....Code 256.....Vin; S650-010101 to ??????
Candy Orange
Europe, Other
1972 XS2.....Code 306, (commonly referenced as 256).......Vin S650-100101 to S650-133900
Brilliant Red/white
US
Europe, Oceania
Pearl Yellow Gold.......Brilliant Red/black
1973 TX.....Code 366, (commonly referenced as 256).......Vin; S650-200101 to S650-217100
Metallic Flake Blue, Pearl Yellow Gold
US, Canada, Other
  • All yamaha models Year-Country.pdf
  • Yamaha model numbers.pdf
1974 TXA......Code 447...VIN 447-000101 to 012150
Cinnamon Brown - Vegas green
New model......
Major changes.....
New Frame;...Whats new..........New Dimensions........Tank/side-covers......Gauge cluster ......Mufflers .....Seat ...... Fenders/Guards .... Taillight.....Triple tree, (longer stem to suit 447 frame).......Crown, (Gauge cluster bolts to crown).......Air Box's
To visually identify the 74-79 standard frame check the Passenger Foot peg bracket. Steel loop welded to the frame
Gauge Cluster; New style. Gauge bracket forms part of the cluster that holds the gauges.....New Brake lining warning light, for when the rear brake shoes wear to a certain depth
Engine; 447 con-rods, (shorter and 20mm small end)..... 447 piston, gudgeon pin position is lower.....447 Cam, (new profile)......Cam-chain and cam-chain sprockets, (at Crank and Cam)........
Minor Changes.
Wheels, (rims), Alloy, Flange W style.......
Rear hub has a Brake Shoe censer for brake shoe wear. Warning light in Gauge cluster
Carbs, BS38's, Jet and Needle changes.........Not linked, 2 throttle cables
No Change
Forks,
34mm....Caliper/Rotor/MC
Interchangeability with early 73TX models
Motor......Wheels/Hubs....Front forks, (not triple tree),......caliper/rotor/MC.......Tank Gas cap.......
1975 XSB......Code 447....Vin 447-100101 to 128650
Star Black.........
Same as 74TXA.....only difference is paint and decals and gauge Speedometer face ..... the Trip meter was moved to the top of the gauge and Speedometer to the bottom
___________________________________________________________________________________________________________________
Europe/England.......Code 553....Vin 447-500101 to (600000)
,75B french.jpg75B ImageUploadedByTapatalk1450087567.322799.jpg Yamaha-20XS650-2075-20-201_3.jpg
NOTE; Major changes to European/English models,
553 Engine;.....longer Con-rods........Piston Gudgen pin position is higher up the piston
Front forks; Twin disk brake set up, (brake rotors are 265mm).........Calipers on rear of fork........Caliper mount brackets are lower on forks.......Axle clamp on right fork/Axle nut on left side.......Fender Braces mount to front fork leg lower down, (US and Oceania front rotors are 300mm front forks do not swap, (mix and match), between Euro and US/rest of the world)
1976 XSC......Code 584....Vin 447 200101 to 211894
French Blue, Brilliant Red
US, Canada, Oceania
Europe.......Code 1E1.....VIN 447-300101 to (400000)
76C Speedometer bought from England......NOS
1977 XSD.....Code 1T3......Vin 447700101 to 724061
Bountiful Blue, Maxi Maroon
US, Canada, Oceania
Mid year gauge change........Brake lining gauge light was removed from Rev-counter and they removed the sender from the rear hub
Europe.....Code 1V2.......Vin 1H1-100101 to (200000)
FRONT FORKS, Major difference
77 to 82 Euro standards have twin front disk brakes with 265mm rotors
calipers are mounted lower on the fork legs to alow for the smaller rotor, (compared to the US and Oceania models using 300mm rotors on the front brake), forks betwen Europe and the US, (and rest of the world), do not swap
1978-E.....Code 2F0.....Vin; 2F0 000101 to 006141
* .................Code 2F0.....Vin; 2F0 00651 to (020000)
Star Black, Spruce Green Metallic
* Mid year change to wiring loom.......From single fuse to 4 fuse bank
Europe.....Code 1V2.......Vin 1H1 200101 to (300000)
1978-SE.....Code 2M0.....Vin; 2F0 100101 to (150000)
Vintage Burgundy, New Midnight Blue
First of the Specials.
XS650SE_02.jpg XS650SE_03.jpg XS650SE_04.jpg 78SE.JPG5 78SE -79SF Special.JPG
Frame.......... Same frame as the Standards with a different rear passenger Foot Peg mount..... brackets for MC for rear disk brake...... Rear top shock mount is set at a different angle to Standard frames
Swing-arm.....Same as the Standard with different brackets for Disc brake set up
Handle bars......New Buckhorn style
Gauge Cluster.......New gauge faces. New tower.. New separate ignition switch
Tank..................New.......Smaller, (than Standard tanks), 12 1/2 liter, Gas cap looks similar the the 76-79 Standard gas cap but does not swap.
Petcocks......Twin, Vacuum operated one to each carb
Side-covers.....Metal with Badge. New shape, same style of fitting as the Standard models, (74-79), slightly smaller top mounts. Does not interchange with standard frames. Can with some slight modification
Seat....... ........Side hinged, stepped seat with half chrome strip. Can interchange with Standard models with some modification to the latch mechanism.
Chrome passenger Grab-rail
Wheels...........
Rear; 16" mag with disc brake..... Front; 19" mag with disc brake
Caliper/Brake Rotor.....Same as 77D..........US, Canada and European, US Custom, had a single front disk brake........Most other countries had twin front disk brake setup
.....MC... looks the same as 77D, MC mount is set at a different angle for new Handle bars........
Forks.........35mm..Adjustable preload caps and some change to the internals. Different to 77D.
Fenders........
......Rear; ....
Shorter than standard guard, new Tail-light and Number plate light mounted with 4 bolts on rear of Guard..........will interchange with standard frames.
......Front; ...
Same as the 77 and later Standards, no change
Fork ears/Headlight brackets...........Different style to standard models.........Silver Chrome, same from 78-83 except 82 has black chrome.
Carbs....BS38, 78/79 set...........Linked, with new jets and needles.
Ignition.......points
1979-F.....Code 2F0.....Vin; 2F0 020101 to (100000)
Colbalt Blue
10847900_604345733025013_6889709398852668844_n.jpg 10628116_604345713025015_4632089074024940597_n.jpg 00I0I_kT5UJFWWh4X_1200x900.jpg 00a0a_fTz11Eg2NIR_1200x900.jpg Clipboard 3 35 mm 1-2.jpg6 79F.jpg
Europe.....Code 1V2.......Vin 1H1 300101 to (300000)
1979-SF....Code 2M0......Vin; 2F0 150101 to (200000)
Black gold, Carmine Red
Identical to the 78SE except for the colour and no headlight on/off witch
1979-2F SII......Code 3N0.....Vin; 250101 to (270000)
New Yamaha Black
Factory Special Budget model.
Same as 78SE/79SF.....Except
Differences.
Headlight bucket, Black
Chain Guard, Black
Riders Foot-peg brackets, Black
Wheels; 36 Spoke
Alloy rims, one year/model only; 16" rear, drum brake. 19" front, disk brake
Side-covers; Decals "Special II 650" instead of badges
Seat, No chrome strip
Valve Adjustment- Video
Cam Chain Tension Adjustment-Video
Different cam chain tensioners
*1980SG, New Model.
US. Code 3G1 - Vin 2F0-200101 to (250000)
xs650SG-4.jpg Yamaha XS650SP 80.jpg View attachment 177609
Major changes-ignition-charging and-Carbs
Carbs; CV, BS34's. Chrome tops with a single feed into a T
http://www.xs650.com/threads/tentative-carb-id-layout.43392/
*Ignition; Electronic Ignition System, (TCI).
*Charging, A Type
Brushes; Both brushes have power, earth is through the SS Reg/Rect
Rotor; New, embedded magnet for TCI pickup
Stater; TCI pickup coil.
Reg/Rect; Solid state Regulator/Rectifier
Frame,
Seat; New shape, clips on.
Side-covers; Plastic
Grab-rail; Alloy
Brake light; Attached to the grab-rail at rear of the seat
Wheels; Mags 16" rear/19" front, Disk Brakes.
Canada. Code 3U6 - Vin 3U6-000101 to (010000)
*Oceania. Code 3W6 - Vin 3W6-000101 to (003000)
Carbs; BS34's
Ignition System; Points
Charging System; B Type,
Brushes; Power on the green wire to brush... Earth on the Black wire.
*Europe. US Custom, Code 4G7 - Vin 3L1-020101 to (400000)
Same as Oceania
fol4G7-1.jpg fol4G7_2a.jpg 17601_0_3_4_xs 650_Submitted by anonymous user..jpg
Same as Oceania
1980G SII..US
*80G/SII visually is the same as the 79 2F/SII...Differences are
Ignition: Factory electronic Ignition, (TCI),
Carbs: BS34's....Visual tell is they had chrome tops/caps
Wheels: Chrome on steel rims. Spoke 19" front/16"rear
Gauges:
Speedo is 80mph limited with red line from 50mph
Rev Counter has high beam light.
Tower changes, Adds the neutral light from rev counter....drops the Taillight warning light.
1981SH
seguss.jpg 00B0B_1nvKkTJdRyD_1200x900.jpg xs650SH-4.jpg8  80SG-81SH-82J-83K XS650.jpg
1981H/SII
Yamaha-20XS650S-2082-20-203_1.jpg 4n9_Special  II .jpg4n9_Special 2 .jpg 81 Special II .jpg 1981 xs650 special 007.JPG 1981 xs650 special 008.JPG8  80SG-81SH-82J-83K XS650.jpg
1982 Heritage Special
Yamaha-20XS650S-2082_3.jpg s-l1600.jpg s-l1600 c.jpg TomDellinger12.jpg TomDellinger13.jpg IMG_20130919_105656_164.jpg
1983 Heritage Special
fol5V4_8.jpg xs650SK-83_half.jpg BillCanfield410.jpg IMG_20130919_105656_164.jpg
BUILDING A BETTER TWIN: by Joe Minton.........Results
BATTERY BASIC'S: A Layman's Guide to Batteries.
Very good tutorial and easy to understand
https://www.batterystuff.com/kb/articles/battery-articles/battery-basics.html
https://www.xs650.com/threads/battery-basics.60463/#post-707772
CARB's
Link to Carb Tutorial including the *carb guide, (PDF), bottom of post 1
https://www.xs650.com/threads/tentative-carb-id-layout.43392/
VM
https://www.bikeexif.com/rebuilding-mikuni-round-slide-carburetor
ENGINE:
...Cam chain tensioner differences
https://www.xs650.com/threads/cam-chain-tensioners.1056/page-2
ELECTRICAL: Tutorials......Basic
XSLeo's
https://www.xs650.com/threads/what-happens-when-you-turn-your-key-on.9625/
Continuity testing.....&....How to use a Multi-meter
https://www.xs650.com/threads/continuity-testing-made-easy.49917/
https://www.xs650.com/threads/how-to-use-multimeter.27826/
Grounds/Earth
https://www.xs650.com/threads/grounds-so-important.41775/
Musings describes this thread well
https://www.xs650.com/threads/wiring-harness-musings.18925/
Fuse-box
https://www.xs650.com/threads/check-those-fuse-boxes.46656/
Ignition Switch, 78-83 Specials..............both threads need to b read
https://www.xs650.com/threads/ignition-switch-overhaul.46712/
https://www.xs650.com/threads/ignition-switch-lock-swap.54928/#post-595755
GAUGE'S; comprehensive, ID/Repairs.
https://www.xs650.com/threads/gauge...0-83-gauge-repair-honda-70-71-750-4-ko.52013/
CHARGING
Jim does a rewind service. He has detailed information regarding the XS650 charging system
https://www.xs650.com/threads/rewound-alternator-rotor.54276/
Relates to Shunt and series regulators for PMA charging system. Off V-strom site but will be of value for PMA systems for the XS650
https://www.stromtrooper.com/thread...gulator-charge-rate-loading-of-stator.435952/
https://www.stromtrooper.com/threads/regulator-shunt-verses-series.435073/#post-5575668
WHEEL CONVERSION; Factory, rear-brake-conversion-drum-to-disk/disk-to-drum
https://www.xs650.com/threads/rear-brake-conversion-drum-to-disk-or-disk-to-drum.51944/
MikesXS 72 left bar switch post #20
https://www.xs650.com/threads/electrical-issue.65120/#post-812956
Chapter 3; Engine section
  • XS750 Mikuni Mk II Carbs.pdf
