2m, I wus thinking of turning a mandrel out of a bolt or such to clean up the pivot on the aftermarket shoes. Machine it to match the pivot pin on the brake plate, cut some angled slots with the cut off wheel in the dremel so it will act as a cutter. Figured I can chuck the mandrel /cutter in the lathe, clamp a shoe to the tool post and feed it in. See any holes in that plan?
Interesting. I was thinking 15mm (or 19/32") chucking reamers. Grind a 12mm dia notch in the middle. If the flutes are long enuff, then there'll be cutters at that smaller 12mm. Otherwise, could separately cut the positioning nub offhand, like I did on my drill press with the 1/2" burr.
This 15mm cutting would put cutting forces across the whole pivot arc, requiring a precise, rock-solid, and sturdy fixture. I can't tell you precisely where to cut, except to try to maintain arc centers, which would be minimal material removal.
The downside? The shoes will settle deeper at the anchor post, you'll end up with a smaller total shoe diameter, as though the shoes are worn down. Plus, initial shoe contact and wear-in will occur largely at the cam area, possibly never reaching the side near the anchor post. Reduced shoe contact area, reduced shoe life.
Long ago, I was contemplating the opposite, some way to expand the shoes at the anchor post, to get full usage.
... I am a lot more concerned about front brake performance compared to rear...
Absolutely agree with your rant. Paramount is good overall braking performance. This whole rear brake thing is of interest to me because:
- The reports of poor braking performance.
- It could one of the "final frontiers" in our XS explorations. Everybody's gettin' involved.
- My personal braking policy has been one of conservation. Long ago, inquiring about XS1 front brake shoes, then getting those blank stares at the Yamaha parts counter, I decided to adopt a conservative riding policy. Using the (more available) rear brakes almost exclusively. Not a problem out here in remoteland with my sedate riding style. The fronts get used as needed, but not wastefully. Since then, I've been able to acquire 2 new sets of front shoes, and have relaxed my "rear preference" policy.
- We have "no front brake" members in here, and I'd like to arm them with good info on rear brake performance...
