69-72 engine mount
They are not all the same, front mount hole in the 70-71 engine block is different (a bit further back?) than the hole location in the 72-83 engines. Frame front mount holes 70-73 are the same.
So you need 70-71 mounts or 72-73 mounts.
They can be a bit hard to find, and it's even harder to tell them apart.
Unlike the 74-83 "rat cage" front mount the early mounts are two bent triangular pieces.
