theDQG
Thread the hub nut back on, stop about 1/2 - 1 turn from seated.
Gently and squarely tap on the hub nut while gently levering the backside of the basket.
Something else to consider, welding your shifter shaft to the shift arm. Our older shifters are press swaged together, later are welded. Mine slipped loose, and I welded it. Look at pics of later shifters to see the welding. Your shifter:
Your trick worked, thanks Steve.
Here's how it looks at this point; what the heck could have caused that grind mark? (yellow arrow). Nothing matches up to it. Nothing on the backside of the clutch basket appears scratched or damaged.
Excuse my mechanical ignorance, I'm not sure I follow re: welding shifter shaft to shift arm?
