thelowlife
So heres my build thread of sorts. Bought a what I was told from the P.O. a 76 XS650. Came with a spare engine a few extras, and a few more issues. I wasn't happy with the way the guy did stuff, his welds were terrible, wiring etc.
The day I got it. I got it early this summer like Juneish. I was working 7 days a week 14+ hours a day on night shift. So after work one day I took a 3 hour drive to get the bike and 3 hours back. Dropped the bike off at my parents shop and then back to work.
I knew getting the bike would require some work. I was attracted to the xs650 platform because of the availablility of parts and support and its looks obviously. I got it running and notice right away that the start bendix gear was shot. After getting it running and going for a little ride some changes were needed. If you can see the maltese cross West Coast Chopper foot pegs didn't even allow you to put your feet under the shifter peg. The guy liked to cut corners and his favourite spacer was 4059 3/8 washers to space the fender, the pegs and you name it.
I started tearing into it right away there was some obvious things that struck me.. but after digging I saw a lot more that wasn't right.
Self tapers to hold the tank to the frame
Shotty wiring
Barebones this is were I saw the shitty welding. I started getting into the engine and the clutch needed a little work.
Painted the front wheel, just after this picture I dropped the wheel and broke the hub
I took off the old hardtrail and start with some new axel plates, bending my own tubing. At this point I was going on the P.O. word that everything was indeed a 76'. I sshould have known better... turns out its a 72 which.
This is how it sits currently. I found some issues within the engine so I'm waiting for my seals, cleaning carbs, and general mock up. I had some problems with the head so lucky that second engine I got came in use and I've been able to swap parts over.
I'm working on my pegs and shift mounts. Shift lever is really bent and won't work it contacts the case. I risk just snapping it in half if I try to straight it out anymore so I'm looking at other options. A YZ lever is fairly 'thick' so I will be able to counter sink the mounting hardware for the shifter. I think I'm going to go with a peg mount from Monstercraftsman or Pandemonium to keep it nice and tight I don't like the look of the modified stock mounts. My knurled pegs are male so I need the female adapter obviously so I have to take that in account, again clean up the mounting hardware.
Shotty wiring
