Hello I've read that a 72 has electric starter but the 72 I have has only kick start, did some of the 72 only have kick start? Thanks
Retiredgentleman i'll have to check that out & get back with you.
gggGary I was told it was a 72 engine with a custom frame & by the numbers on the engine it is a 72 but as for the frame there are no numbers at all on the neck. This a project for me and is going to be my first motorcycle build i have ever attempted. Thanks for all the help.
TwoManyXS1Bs thanks. Can you tell me what else stood out that its not a xs frame beside the neck.
... The upright behind the motor and the straight section below it could be original.
Does the left exhaust valve cover have a cable operated lever, with the cable going up to the handlebars?
No but there's a small lever on the bars that doesn't have anything attached to itDoes the left exhaust valve cover have a cable operated lever, with the cable going up to the handlebars?
