73 TX650 Gauge Trim/rubber
Oddjob
adsgads
Burnaby, BC
Would anyone know if the Gauge trim rubber on a 74+ TX650 instrument cluster (item 13 below), is the same as the trim on the 70-73 gauges?
Partzilla 74 diagram:
The part number as per the 74 parts diagram is 371-83513-70-00 and is still available as NOS on ebay, etc. I would like to replace the worn/damaged ones on my 73 if I can somehow confirm that they are identical.
Partzilla 73 diagram:
A better picture of the trim from Mailman’s 72 restoration:
3d696dfb-2c8b-4155-add2-5d2cac0a122d-jpeg.114920
If you have independent clocks, like the part diagram and Mailman's pic shows, I am afraid not. Those 74 gauges look exactly like RD350 instument clusters, and those rubbers look different, they have a flat bottom that sits "on" the bracket, not inside.
Hi ArcticXS... not the answer I was hoping for; but nonetheless, I appreciate your input...
I guess if it would have been that easy then someone would have already figured that out...
Cheers,
:cheers:
