JeremiahL
Hello all,
As you can tell I'm new here, I signed up a couple weeks ago and have been soaking up as much information as I can.
I recently picked up a 75 XS650 in pieces that the PO had been rebuilding. He said the bike had no compression when he bought it and he found the rings were stuck in the piston grooves. He lapped the valves, and I think got the jugs and head back on but said he bent a ring in doing so and scored the bore pretty decently. So I'm guessing he got it together and found out he still didn't have compression in one cylinder and took it back apart. This is the state that I got the bike in.
On to my question. I figured before I spent the money and time getting new pistons and reboring the cylinders I should make sure everything felt alright in the bottom end and transmission. I was turning it over by the counter shaft sprocket and shifting through the gears tonight, and when I hit fourth gear the countershaft spun freely for about 20-30 degrees before it started moving the crank again. every time I rotated it around to the same spot I got the same result. Would I be correct in assuming there are some missing teeth or could this be something else? If it is broken teeth should I just plan on replacing the whole gearset? Anything else I should check on the bottom end before I get in too deep on it?
