'75 Carburetor Diagram, Picture?
16vsilverstreak
Bristol,TN
Hello, does anyone have a diagram, drawing, picture of the carburetors on a '75 XS650? The carbs I have require two throttle cables, one carb is choked, and it appears they have balance pipes between them. When I obtained the bike the carbs had already been removed along with all tubing and fuel lines. Are there any brackets that help hold the carbs or are they supported by the manifolds and air box. I'm running pods, no air box. What brackets would you recommend? Thank you.
How about this one?
Factory rubber spigots with the steel collars should be enough to hold the carbs up.
