I've had my '75 for 5 years now and it has always been a bit quirky in the charging domain, compared to my '76, '83 and '82 which give me consistent numbers on the voltmeter.
The '75 is running and starting well, but the numbers concern me a bit. I'm interested in others' opinions.
Background:
The regulator is a VR-115 (replaced last year) It is rated to regulate from 13.8 to 14.8v.
Rectifier is a modern cheap Chinese "Centry" 35 AMP 3 PHASE unit, wired it myself (correctly).
I've inspected/cleaned all the wiring connections.
New BigCrank 220cca battery this month which I fully charged.
Modern fuse block.
Slap test is OK
Brushes are good.
Rotor: 5.3 , No shorts.
No voltage drop at the brown wire going to the reg.
Probing the back of the stator connector (3 white wires) at idle, I get 12.3v on all 3 of the combinations.
I just installed an onboard voltmeter and the new battery. All my XS's got a BigCrank this year.
Voltmeter is wired directly to the battery and switched (mini toggle)
On the first long test ride sunday, I was initially getting 14.4v on the meter at speed, but by the end of the test it was only 14.1. At idle it is 13.5.
On the second long test ride yesterday I got only 14.0v, and by the end of the long run the number was 13.9.
It seems to be charging well; after sitting for 22 hours, the resting voltage is 13.1 this morning. However, maybe (?) it is overcharging, as my other bikes all are at 12.9 after resting overnight.
Background:
Modern fuse block.
Slap test is OK
Brushes are good.
