When you had it apart for the shoes did you take the acuator shaft out and clean/lube it. I just had the rear wheel of the 81 for chain and sprockets. The brakes have been noisy for awhile now. While the wheel was off I took the shoes off and removed the shaft. Marked the end where the lever on the out side sets so I could get it back on right.
I had to use a bit of persuasion to get it out. Hammer and punch.
Steel wool for cleaning shaft and area that touches the shoes. The hole the shaft goes through.
I just replace the rear wheel bearings on the van so had some fresh wheel bearing grease. A thin coat on the shaft, the area the touches the shoes and cleaned and regreased the felt washer on the out side. The shaft slipped right back in and spun in the hole very easily.
Ah! much better.
Now with reassembly no more noise. With the stiff action of the shaft the shoes dragged a bit making the noise.
Holding the brake as you tighten the axle centers the brake plate and shoes in the drum. This helps the brakes by having both shoes hit the drum at the same time. With them off center one shoe hits before the other.
Having a helper while doing this helps. Or screw the adjuster nut on the rod down enough to do the same thing works, just remember to loosen it back to proper adjustment.
