nhsteve
Currently working on a '78 standard that even with 32,000 miles on it seems like it has had some real love over the years and miles. Lots of evidence of being well cared for. I bought it as a "runner - with a bit of help needed". I did hear it run on 2 cylinders, even rode it lightly (no front brake- caliper bleed screw completely buggered beyond repair). Things seemed ok beyond needing brake work and tires.
Soooo................ I've sorted the front brake, & replaced the cup/cone steering bearings (which had actually been repacked at least once, as the grease was quite good) with taper rollers. In the process of reassembling everything and checking light operation, when I turn the key on, the tail light comes on, regardless of the headlight on/off switch on the right handlebar switch (which does indeed control the headlight). Virtually all other lights act correctly/as one might expect.
Is this correct?
My '77 Standard does not do this, but looking at the schematics in my 'lovely' wink2 Haynes manual, I see that this makes sense (?). The '78 main switch has but 3 wires, red, brown, and blue. Key 'on' connects all three together, the blue lead goes right back to the tail light, I do not measure any odd voltage at the tail light, it just seems odd that Yamaha did this . If they put an on/off switch for the headlight, why have the tail light on all the time?
Any comments from another '78 Standard owner? I'm not going to obsess over it, just curious.
Is this correct?
