Seven year old thread but sometimes synchronicity occurs.
Fusing the blue wire for the tail light is a grand idea. Just the other day I was twenty miles from home visiting a friend. He had gifted me some woodworking tools which I strapped down hard to the back of my seat. Leaving, I got about a half mile away when the bike died. 90 plus degrees out, rolling hills, no homes, no phone and no tools.
Unstrapped the tools, lifted the seat and checked the fuse panel. Main fuse blown. Put the spare in. Started, put her in gear and died. Checked the fuse panel and main fuse blown. Checked the wiring. Some loose to the rear that could have pinched but nothing obvious. Moved one of the other fuses to the main fuse slot, as I had no spares. Key on, fuse blows. Now I'm down two fuses and still not running. Checked around again for any possible shorts. Moved some connectors around under the seat until I was satisfied that the problem had to have gone away, yeah, and then figure how to re-fuse with no fuses and no foil to wrap the bad ones.
This fuse panel is an aftermarket for the glass fuses.
I noticed that the fuse clips could be slid out of the plastic holder, so I slid two of them out from circuits that hadn't blown, turned the clips upside down and inserted them into their opposite clip. Main fuse was now powered with a 10 amp fuse and two circuits were direct wired. Here we go, kicked her over, put her in gear and still running..........home, James!
