IronHeartCycles
Happy Holidays!!
20% off your entire order when you use discount code IHC20 at check out!
This setup is a direct swap if you have a 7 pack clutch already 1974-1979
You will receive
$160
8 new clutch plates
1 new steel plate
1 set of our clutch spring retainers
1 set of EBC heavy duty springs
1 HD thrust bearing and washer
If you have a 6 pack clutch we will offer machining service to fit this setup. (1980-1984 will need to be machined.)
$200
8 new clutch plates
2 new steel plate
If you have a 1970-1973 you will receive.
$205
8 new clutch plates
7 new steel plate
This is one thing you don't want to over look in a build! Whether your clutch is beginning to slip, your building a fresh motor, or have one already built up. These kits are perfect for all applications, and provide tons of grip. With the clutch plates being slightly thinner than stock this allows for the extra clutch plate and steel plate to fit. Giving you that extra grip when you dump the clutch.
Machining service will be $45 (includes the return shipping cost. The price is $200 for the kit and machining. Big Cartel wont let me have different shipping prices for the options, so the price has been adjusted to make it work. )
Shipping info http://www.ironheartcycles.com/shipping
You will receive
$160
8 new clutch plates
1 new steel plate
$200
8 new clutch plates
2 new steel plate
$205
8 new clutch plates
7 new steel plate
