Normal braking shouldn't upset the motor, long hard stops often will.
Gas was leaking from where?Fixed the gas leak using the very cost-effective Fel-Pro radiator seal: https://www.autozone.com/cooling-he...mostat-gasket/fel-pro-thermostat-gasket/68354
One more thing off the checklist...
A 1-1/16" socket is a perfect fit.OKAY, never mind, searched the forum, and apparently they're 27mm.
Now I just have to go get one.
To check the sump filter and clean it. You might wanna get a gasket for it just in case...why do I have to drop the sump plate?
Well, dang.To check the sump filter and clean it. You might wanna get a gasket for it just in case...
